Crane Cams
1 Attachment(s)
Crane Cams and its parent company Crane Technologies Group was originally known as known as "Crane Engineering Company, Inc.", and was founded in 1953. In 1970 the original name, "Crane Engineering", was shortened to "Crane Cams, Incorporated", better defining the company's products and market of that era.
From that very humble beginning, Crane Cams has evolved into a nearly $50 million dollar per year manufacturing and marketing company. Amazingly, it all began in an unused corner of company founder Harvey J. Crane, Jr.'s father's Hallandale, Florida machine shop. |
Rocker Arm
1 Attachment(s)
High performance, recreational and racings most popular aluminum rocker arms since their introduction in 1964.
Now, over four million rockers later, the nation's leading racers and engine builders know they can trust the strength, ratio accuracy, quality, and reliability of Crane's famous gold anodized, aluminum rockers. |
1 Attachment(s)
Crane Hydraulic Roller Lifters
Roller Timing Chains
1 Attachment(s)
Pro-Series Steel Billet Gear and Roller Chain Sets
Fuel Pump Push Rod
1 Attachment(s)
Mechanical fuel pump push rod for hydraulic camshaft
Teflon Valve Stem Seals
1 Attachment(s)
Teflon valve stem seals provide maximum valve stem oil control and retention. These high-performance seals wipe excess oil from the valve stem, preventing unwanted oil from reaching and contaminating the combustion chamber or ports. Machining may be required on stock guides.
| All times are GMT -5. The time now is 04:18 AM. |
