Dart Big M & Little M Blocks
Are you looking to replace your stock engine block with a stronger then stock piece? Dart definitely has a solution for you. These blocks have thicker cylinders, decks & main webbings. What does this mean to you? It means you can build a bigger, stronger engine that is more reliable.
We carry the Dart Big M 9.8 Short deck block. Bore sizes available from 4.250 - 4.600. I have these blocks in ductile or billet cap versions. Just think you can build anywhere from a 454 to 565 cid engine on the big m. Prices: Big M w/ ductile caps $1725.00 w/ billet caps $2025.00 Also available Little M blocks: 4.00 - 4.125 bore sizes available with 350 mains, ductile caps $1600.00 Call Albert @ Cobra Power 305-893-5018 |
