-   New Products and Member Discounts (https://www.offshoreonly.com/forums/new-products-member-discounts-139/)
-   -   Mayfair Add-On External Hydraulic Steering System (https://www.offshoreonly.com/forums/new-products-member-discounts/91082-mayfair-add-external-hydraulic-steering-system.html)
CPPerformance 11-24-2004 12:00 PM
Single Bravo, Single Ram Add-On Hydraulic Steering System
http://www.cpperformance.com/images/137-9251.jpg
This kit includes:
(1) Starboard Steering Cylinder
(1) Bravo End Cap
(1) Bolt Kit
(1) Bravo End Cap O-ring
(2) -6 AN X 1/4" 90 Degree Brass Fittings
(2) -6 AN X 1/4" 90 Degree Stainless Fittings
(2) Braided Stainless Inside Hydraulic Hoses
(2) Braided Stainless Outside Hydraulic Hoses
(2) Thru-hull fittings
(1) Installation Instruction Manual
NOTE: Brazillian steering manifold or Saginaw shuttle valves must be ordered separately.
The high performance Mayfair by Hardin Marine Hydraulic Steering System is recommended for most sport boat applications. This arrangement gives additional support for even tighter, more firm steering control. Generally speaking, it is recommended to use external power steering on boats which run in excess of 70 MPH, however there are some boats that run 60 MPH that would benefit from the use of external power steering. The new Mayfair by Hardin Marine steering systems use a 316 stainless steel rear cap that is highly polished and is supplied with all stainless fittings, thru-hulls, bolts, and pre-made hydraulic braided stainless lines.
Order online for the low price of $1295.99!
sonic33 03-10-2014 11:02 PM
This kit includes:
(1) Bravo End Cap
(1) Bolt Kit
do you sell a kit for twin trs drives
looking for a add on kit
