Bad Kitty, making things happen.
#111
#112
I fixed the heads and sold the engines to Anthony at HP Mafia. He tuned em earlier in the year . he liked em, says he will replace cams and make em great again.
My plan was to convert to Holley and start fixing the fuel distribution issues. Modified my headers for 8 02 sensors and bought all the holley stuff but Anthony also likes Mefi so I kept all the holley stuff.
Time to stop building garabage motors and go a different route , I can`t keep doing the same thing over and over expecting a different result.
#113
I believe I might be able to assist you with having some anodizing done. I'll check with my source to see if he could do the color stripping and anodizing for you. I'm sure he can take care of it and he also does the laser engraving and etching just in case you want some custom touches done. He already makes quite a bit of boat related eye candy in his machine shop already.
#114
#115
If he could paint the whipple too , bonus!
LMK
#119
Eddie had some crank sensor issue and didn`t get to make a pull.
Hoping he figues it out today.
It`s 112* heat index. Probably 120* in the dyno room.
That`s not great for blowers but it is what it is .
In the meantime I hooked up inverter, isolation relay, 200AH battery.. Now I can run the AC without having to plug in.
#120
That's a pretty cool set up, the AC in my boat pulls 12amps of 110vac with all the pumps, fans and compressor running. So I am pretty much stuck running a generator unless I want to redo everything. How long will that battery run you new AC unit? Enough for a overnight?
