-   Nordic (https://www.offshoreonly.com/forums/nordic-99/)
-   -   Bravo 1 pitch for 525hp (https://www.offshoreonly.com/forums/nordic/126695-bravo-1-pitch-525hp.html)
Rage 04-05-2006 08:49 AM
What is the standard pitch for a stock Bravo 1 on a Nordic Rage from the factory with a EFI500/525hp. What would be the Bravo 1 pitch in a lab finished configuration for the same boat / engine?
Steve Zuckerman 04-05-2006 11:32 AM
Re: Bravo 1 pitch for 525hp
Rage,
I think you could pull a 28B1 (which is really a 27").
I would try a stocker (you can modify it from there), and see how it runs. Get a loaner from a prop shop or friend before you plunk down the $$.
Has anyone tried a P5 on a Rage?
Steve
Nordicflame 04-05-2006 04:34 PM
Originally Posted by Steve Zuckerman
Rage,
Steve
They seem a little stern light already. 5 blade may make that a bit worse. Never know til you try though :cool:
28 or lab 30 if at 525 and sea level.
Dave
bobl 04-06-2006 05:36 PM
The Rage does not have a lot of prop slip. Here are some real world numbers for an open bow version. Stock 26 pitch = 5000 RPM/73 mph, 5600 RPM=80, 28 pitch runs the same 80 at 5200 RPM and a 30 pitch 80 at 4800 RPM. This is with a mild 540/600HP engine.
Nordicflame 04-07-2006 08:11 AM
Bob,
Nice torque curve on that 540!! I'd say by the looks of that the torque curve is pretty flat.
The 73 at 5000 w/26 is with the 496HO, correct?
Dave
Rage 04-10-2006 10:22 PM
I wonder if I have a hook in my hull or something. 68mph @5000 rpm with a stock 26P Bravo 1 is all I could ever muster with the stock 496HO. Assuming the 26P Bravo 1 is a true 25 pitch (as the prop people tell me) leaves me with a 14% slip I believe. Additional HP is my answer.
bobl 04-10-2006 11:36 PM
I got to test run the Rage I upgraded to an HO this weekend. Running a stock 26 prop It ran 72.6(GPS) at 5100 RPM. So, the upgrade got almost 5 MPH and 400+ RPM boating at the same place, similar weather, load, etc.
Rage 04-11-2006 08:19 AM
Wow! That was an upgrade from what engine horse power?
Assuming a true pitch of 25" for the 26P Bravo 1 that would be 72.6/80.5 or 10% slip. How many people in the boat and gas in the tanks at 72.6 mph?
Bill
Nordicflame 04-11-2006 10:44 AM
Bill
From a standard Mag, non HO.
Rage 04-11-2006 10:53 PM
5mph increase from 50 HP. That is very nice.
Was it driver only or more riders?
