-   Nordic (https://www.offshoreonly.com/forums/nordic-99/)
-   -   28 Heat Mph (https://www.offshoreonly.com/forums/nordic/188976-28-heat-mph.html)
crowntow 06-15-2008 09:40 PM
28 Heat Mph
what mph does a 28
heat run w/stock 496?
johnlomant 06-15-2008 09:47 PM
64-68 gps depending on elevation and conditions but the new carbon kevlars are suppose to run into the 70's
juicybusa 06-16-2008 03:30 PM
About 30 mph less than a 540 pro-charged Heat. I love suprises-don't you???
johnlomant 06-16-2008 05:20 PM
Cant wait for the regatta its going to be a blast. I hope to have the boat running by then.
I DIG IT !! 06-16-2008 09:59 PM
I have a 02 Nordic Heat with a Whippled 496ho and it runs high 70's on gps. I ran 63 to 64 stock at 1500 feet. The Whipple made the boat feel and drive soooooo much better. The Heat likes speed and power. The boat and hull did not skip a beat. I think that it woke it up :D
nedpoole 06-18-2008 04:26 PM
Dig it, what prop are you running now after installing the whipple?
do you have external steering? are you running an XR bravo drive?
thanks!
Ned
check it out 01-29-2009 05:59 PM
how fast do think a 29 ft will run.525sc 5000ft abcl what can i do with this motor .the boat is a 96 the motor has 70hrs
playen with props
Steve Zuckerman 01-30-2009 10:14 AM
playen with props
Around here (500 ft altittude) that's low to mid 70s boat.
At 5000 ft, you'll have a significant loss in horsepower due low atmospheric pressure. What can you do within reason? Add an intercooler and turn up the boost a little.
BTW, if your boat is a Heat (I think it is), it's a 28'.
Steve
check it out 01-30-2009 06:13 PM
my boat is a 96 this before they called it a heat its a true 29ft . have u heard about keith eickert efi throttle body scoop?
