Help with a door switch
We managed to push both door switches at the same time in opposite directions. After replacing the fuse, the switch on the dash no longer works. I have traced the wiring from the dash switch along the dash until it disappears around the interior walls and didn't see an in-line fuse. ( No voltage to the switch) Any ideas? It's in a 28 Heat.
:mad::mad: |
Originally Posted by boaterh
(Post 2671050)
:mad::mad: 1 is located within the panel inside the cuddy (the one you've replaced) The other is located under the cup holder by your throttle and gear shift levers. Pull that cup holder and your in-line fuse should be sitting right there in plane view. |
Fuse is under the cup holder behind throttles. Pull the cup holder you'll see the fuse.
THANKS for the responses. I will check for the fuse next time out.
| All times are GMT -5. The time now is 03:36 PM. |
