2000 Nordic heat porta potti model #?
i bought a used 2000 heat and i need to know the model number of the porta potti that fits in the FW compartment under the bed
thanks! Ned |
Ned,
Just pee in the lake man..........I know, it's for the ladies. I picked up a Porta Pottie 235 @ Camping World. Works great. Also, get the hold down brackets to keep it from banging around in rough water. West Marine has a pretty good selection too. Steve |
i've tried to get the ladies to pee in the lake too but they insist on having privacy... whatever!
thanks for the info... -Ned |
Steve,
so did you mount that 235 in the cubby under the bed or in front of that between the bench seats? thanks Ned |
Originally Posted by 05R1
(Post 2712150)
Steve,
so did you mount that 235 in the cubby under the bed or in front of that between the bench seats? thanks Ned Under the bed, behind the access hatch. The front hold down bracket had a release latch so you can pull it out. Steve |
Originally Posted by Steve Zuckerman
(Post 2712154)
Ned,
Use a cup
I dont keep a potti on the boat because I had a instance a few years ago where somebody took a dump in it. I just threw it away. Wife complained so I got a rectangular gallon plastic OJ container, mixed the OJ with vodka, & cut the bottom out. Works great, fits between the leggs well. Just rinse after each use.
| All times are GMT -5. The time now is 01:56 PM. |
