-   Nordic (https://www.offshoreonly.com/forums/nordic-99/)
-   -   25 rage what prop ? (https://www.offshoreonly.com/forums/nordic/204468-25-rage-what-prop.html)
Smoothsix 03-08-2009 11:26 AM
25 rage what prop ?
25 rage 496ho xr drive with a 1.36 ratio what prop should I run ? If nobody knows because of the 1.36 please tell me what prop you are using with a 1.50 gear I know that is a more common setup thanks .
Plane Silly 03-08-2009 05:46 PM
You are in the right place, I'm sure someone with that combo will chime in soon. I run a labbed 26 4 balde ( I think, there are no markings on it) on my 1:36 but also have a lot more power. Have you tried the prop calculator?
Smoothsix 03-08-2009 09:55 PM
Have not tried the prop calculator , is it on oso ?
johnlomant 03-09-2009 07:29 AM
Wht 1.36 with only a 496ho/ That does not make sence. I would switch to 1.50 first and then prop the boat. The gear ratio is for 110 plus boats not 70's. Are you sure that it has 1.36. If so you acceleration is being hurt and the top speed also.
Plane Silly 03-09-2009 08:27 AM
I agree that a 1:50 would be better. Mine came with a 1:36 so unless I can find someone to swap with, it's going to stay that way.
You can do a search for a prop calculator there are lots out there. Here is one I found real quick. http://www.rbbi.com/folders/prop/propcalc.htm
johnlomant 03-09-2009 08:50 AM
That is the same calculator that I use
CB-BLR 03-09-2009 10:12 AM
Probably a Mercury Lab 22 pitch Bravo 1
Chris
