-   Nordic (https://www.offshoreonly.com/forums/nordic-99/)
-   -   500 efi question (https://www.offshoreonly.com/forums/nordic/216611-500-efi-question.html)
Linster 09-16-2009 08:14 PM
Originally Posted by chase8 (Post 2953955)
Linster,
Are you the mechanic that did the rebuilds on Jima97's Flame. I have been talking with him, and I spoke to John at Unlimited about it. Sounds like a real nice boat for a 2001. I guess the drives have not been freshened. What would you recommend where they are concerned? Thanks
Yes I did the engines, the previous owner did everything I requested. about 5K on the rebuilds, not counting the labor. I also did the AC install. Both are first class. Dont worry abuut the drives. Keep the oil changed and you should be fine. I put on the nose cones as well. 500EFI's are good on Bravos.
Linnie
chase8 09-17-2009 11:21 AM
Thanks, I appreciate your input.
90mphRAGE 09-17-2009 03:51 PM
I have a HP500 EFI in my Rage. It lost a head gasket @ 300hrs, though mine is Whipple charged. I suspect it didn't have much left in it anyway. I had to go through the whole thing. (bore, pistons, cam, heads, valves, rockers etc.) The rockers have a tendancy to ride the valve everywhere but the stem. I spent $14K because of water damage. Play it safe & have the top end done @ 300hrs. The bottom end should be fine & the tops can be done without removing motors. Spend a little to save alot.
