-   Nordic (https://www.offshoreonly.com/forums/nordic-99/)
-   -   Winter Flame Projects Complete; Some Preliminary Results (https://www.offshoreonly.com/forums/nordic/232415-winter-flame-projects-complete%3B-some-preliminary-results.html)
Linster 06-24-2010 03:33 PM
Originally Posted by Nordicflame (Post 3144162)
Yes that did come up in our many conversations :drink:
Maybe you guys have some ideas here. I'm still having a small problem with a lean area around 4000-4300 rpm (13.3:1).
Not when I'm powering thru but when I just hold it there. Seems like it just goes back into vacuum far enough to close the PV there. As soon as I touch the throttle she goes rich again which is good. I'm hesitant to fix my rich cruise and WOT until I get this resolved.
The original jetting/PV setup was 82 square and 4.5PV front/rear. The mfr suggested I try 6.5PVs to see if it kept it richer there but it didn't help.
I thinking of going back to the 4.5 PVs with 82 jets in the primaries and plugging the PV and install 90s in the secondary. Just a thought...
A power valve usually adds about 8 jet sizes. Going to 90 and plugging the valve should be equal. Do you know at what RPM the secondaries begin to open? They should be opening at that RPM. Try putting some 84's in the secondary only, if it gets better see what it does elsewhere. Thats the problem with carbs. You need to WOT right, then make everything else just be happy.
eastsideoffshore 06-24-2010 05:20 PM
Originally Posted by Nordicflame (Post 3144303)
Just into the secondaries... (I can feel the secondary spring)
Go to the next stiffer power valve on the secondaries to keep it richer in the transition area.
Chris
CB-BLR
Nordicflame 06-24-2010 09:38 PM
Chris
CB-BLR
Went from 4.5 to 6.5s. No difference.
