-   Nordic (https://www.offshoreonly.com/forums/nordic-99/)
-   -   Nordic Rage Speed Question (https://www.offshoreonly.com/forums/nordic/243073-nordic-rage-speed-question.html)
Mach80 11-25-2010 10:09 AM
I have a 2001 Nordic Rage with a stock 454 MPI. I am wondering what other have seen for top speeds with either the stock 454 MPI or the 502 MPI.
Thanks.
XX14 11-25-2010 10:15 AM
496ho
pushes us to around 70 with seven of us and close to 75 with a couple of us and half full tanks
bobl 11-26-2010 03:42 PM
The 502 should run about the same as a 496 HO, generally low 70's. The 454 depends if you are talking about the 454 Mag(385 hp) or the 7.4 MPI (310 HP). I would expect the 454 Mag to run near 70 and the 7.4 mid 60's.
What is yours running?
Thanks.
Mach80 11-26-2010 06:51 PM
Mine is the 454 MAG. It's running 68 currently on GPS. The motor is apart now due to very poor compression and poor leakdown. I should have checked it out better when I bought it! I've fixed the compression and am hoping for some good performance now as I have also done Tyler Crocketts 100HP upgrade kit. Thge engine will be running in a few days and hopefully in the water shortly after. Just looking for a baseline what it should have done stock.
XX14 11-26-2010 07:28 PM
Temper those expectations...
The Rage is one of the best power to performance packages available. 70's nothing to sneeze at and increased mph requires exponential $$$$$ spending. A lot of folks spend a lot of money trying to break the 70 barrier and our boats pretty much do it at will. I do understand though 75 makes one start thinking about 80.
nordic28_wk 11-27-2010 12:06 PM
My heat does 68 with a 496HO but I have a buddy with a rage that gets 83 with a 500efi (blue motor) and a 28P B1
spyderconv1999 11-27-2010 12:39 PM
i have seen 72.7 with two peps, 496HO and a 28p, on the 06 i recently sold...
apaolillo 11-27-2010 05:00 PM
[got a 94 scandia same as rage. 502 efi 1.36:1 outdrive. Runs 74 with full tanks. 26p mirage
Rage 03-31-2011 09:49 PM
What elevation are you running at?
LB NORDIC 03-31-2011 10:34 PM
mine runs at 454 385 hp and it runs at 68 with a bent prop
