-   Nordic (https://www.offshoreonly.com/forums/nordic-99/)
-   -   Newbe Prop Guidence (https://www.offshoreonly.com/forums/nordic/256129-newbe-prop-guidence.html)
dawnpatrol 06-19-2011 07:44 PM
Newbe Prop Guidence
Need some advice on what to get and where to buy...
Just got home today from a weekend at our lake of choice in New Mexico. Ran out the new to us boat (Nordic Rage 496HO) and need a new propeller.
The boat came from Havasu with a Bravo 1 26P 4-Blade. I borrowed a buddys 22P Bravo 1 and got the following results:
Elevation 6100'
GPS Speed 61.5
RPM 4900-5000
I put the 26P back on and was only able to get 4500RPM @ WOT so I oviously need something smaller.
Thinking maybe a 24P. I have been told to stay with the Bravo 1 and rework it if needed.
All reccomendations on what to get and where to buy will be greatly appreciated.
Thanks in advance,
Steven
Steve Zuckerman 06-20-2011 08:32 AM
Hi Steve,
Welcome to the Nordic Forum and congratulations on your new to you Rage. It is interesting how high elevation has a negative effect on performance.
I think you are heading in the right direction with the 24" B1. It will probably pull your RPM back 200/250 RPM, but you can get some of that back with blueprinting, 150 RPM+ or -.
If there is a local propeller store with experience building props for high elevations, that would be good. If there isn't, BBlades does a great job, and has a propeller test program.
www.bblades.com
Regards,
Steve
