question on imco 3 inch shorty
Has anyone ever tried a 3 inch shorty on a non step v 28 heat. The boat is a 1998 heat.
Originally Posted by powerquest12345
(Post 3443950)
The boat still has plenty of lift, and planes off without cavitation, so a -3" might work. It's overall handling characteristics (less porpising, high speed stability) are better too. It also depends on how much horsepower you are running, and what type of propeller. The higher the horsepower to weight ratio of your boat, the higher propshaft height you can get away with. You may have to run a propeller with larger diameter, more blade area per blade, or more blades (like going from 4 to 5). A 3" change in propshaft depth would be pretty radical. I would try to find one to test before laying out the $$$. Regards, Steve |
thanks
i was thinking of going with a 3 inch with xz drive because i can get a deal on one , My brother in law is SLV Villian he has a 2 inch speedmaster he planes out really good, ill keep you posted thanks for your info |
Something to think about...........you can use a 1" spacer on the -3" shorty if it does prove to be too high, getting you back to -2" net propshaft depth.
How much horsepower are you running? Good luck and keep us posted with your progress. Regards, Steve |
Right now im running a 500hp carb, bravo 1 outdrive with 26 bravo 1 prop, I purchased a procharger system that i half to put in .They say at 5psi 710-740hp well see and i have the 3"shorty i half to install also i dont know were to start for a prop
3 inch shorty
one thing to remember is with a three inch shorty you have to cut the rear of the drive off to clear the blade but this may help the older heats they did have a very deep x demension
i just put a 1'' spacer because the boat did not want to plane and yes i had to cut the back off the spacer looks like the drive was already done was very easy to do. will try out the boat this afternoon will let you guys know how i do
(Post 3446093)
works really good planes out good i still have to get a few things for the procharger i just want to ride the boat the weather is awesome
(Post 3473649)
| All times are GMT -5. The time now is 03:40 PM. |
