-   Nordic (https://www.offshoreonly.com/forums/nordic-99/)
-   -   Prop for a heat open bow?? (https://www.offshoreonly.com/forums/nordic/257694-prop-heat-open-bow.html)
kennyo 07-11-2011 09:02 AM
Which prop would be best for a 2006 Open bow w/496HO?
CB-BLR 07-11-2011 09:14 AM
Probably a 26 pitch Hydromotive P5x
This is a great all around recreational prop...it pulls hard out of the hole...has excellent midrange cruise speeds...and is pretty good on the top end.
I have found that the Mercury Bravo props are a couple of mph faster on the top end...but give up drivability on the bottom end. (they do not come on plane as easily...and are a mph down in the midrange)
Hope this helps,
Chris
powdercoat777 07-11-2011 10:42 AM
how about with a 525
Steve Zuckerman 07-11-2011 11:21 AM
I think our old buddy boatingbent ended up with a 27 P-5X and a 1" spacer. I've searched the forum and I can't find that thread for some reason. I am pretty sure he bought it from Bblades, so they should have his records.
Regards,
Steve
What's on it now and how many RPM does it turn?
Regards,
Steve
bobl 07-11-2011 05:38 PM
Bent bought a 26" P5X but it proved to be a little big in hot weather. I traded him a 25" P5X for it. The 25 works good with a 496 Also. A labbed 26" Bravo is probably the fastest on a stock 496 Heat. I just happen to have a perfect Bblades labbed 26 Bravo available if anyone is interested.
Bob
Regards,
Steve
bobl 08-16-2011 09:26 AM
Cumberlandheat - your PM box is full. To answer you question the Bblades S/N is on the box I sent the prop in. I think a 25" P5X may be your prop of choice, but will drop your rpm about 100 below a stock 26" Bravo 1 prop.
