-   Nordic (https://www.offshoreonly.com/forums/nordic-99/)
-   -   Drive spacer (https://www.offshoreonly.com/forums/nordic/292836-drive-spacer.html)
05 Nordic Heat 03-11-2013 02:21 PM
Drive spacer
Ok I'm finally buying a drive spacer in two weeks for my Nordic heat. I was wondering if I need to buy an extra O-Ring kit for my outdrive? I know the spacer comes with O-Rings, It seems to me when you split the upper and lower you would need them on both sides of the spacer? Any help on this issue thanks!
Randy Nielsen 03-11-2013 03:44 PM
I did a couple of spacers on my drives & just used the old o rings, they don't supply a double set with the spacer. They are cheap enough to buy if you feel you need them. Randy
