-   Nordic (https://www.offshoreonly.com/forums/nordic-99/)
-   -   cabin door (https://www.offshoreonly.com/forums/nordic/295826-cabin-door.html)
ltl driver 05-05-2013 08:06 PM
cabin door
I think the door has come off the track or what ever it rides on or in, it won't close. whats the best way to fix it?
raytart 05-06-2013 08:11 AM
Remove panel behind dash and take a peek, although very limited access. Or remove the entire panel where the stereo is mounted. That gives decent access to the motor and the antenna looking screw type drive. It is also possible that the hitch on the door came loose and detached, it's a pain it the rear to work on this.
Have fun
Rjcrock1974 04-24-2019 07:51 AM
Did you find a way to fix it? I have same/similar problem
03CanaryYellowHeat 07-24-2019 10:35 PM
My door is stuck open also. The is a power draw when you hit the switch, but the door doesn't try to move
