Older 28 Heat exhaust question....
Has any one had reversion problems running a Crane 731 cam with stock exhaust manifold? The boat is a 97 and the way the factory pipes run out of the exhaust i'm not sure if I can run any type header.. Any feed back??
Hi Kenny,
I know you know that is a "big" can for stock exhaust. Even if it doesn't have reversion issues, it wont be very efficient. A '97 is going to be set up with a low XD, but other than that you shouldn't have any trouble adding headers. Butch had the notoriously bad non-stainless Lightnings, and now has much nicer CMIs. They both fit with no problems. He did have to have his old transom outlets glassed up when we switched to corner exhaust. Crafton's boat is a '97 and it has factory CMIs, I think. I haven't seen it for while...... Good luck with your project. |
Originally Posted by Steve Zuckerman
(Post 4163347)
Hi Kenny,
| All times are GMT -5. The time now is 07:08 AM. |
