-   Nordic (https://www.offshoreonly.com/forums/nordic-99/)
-   -   Rage is great on fuel!! (https://www.offshoreonly.com/forums/nordic/328144-rage-great-fuel.html)
zgoo 07-06-2015 06:02 PM
Spent three days running aroung in my Rage over the 4th and started with full tanks and had just a touch under 3/4 tanks on Monday. Really impressed with the low fuel use!!
Sydwayz 07-06-2015 06:09 PM
Remember, your fuel tank gauge is NOT linear in it's reading. The bottom of your tanks are V-shaped to some degree, not square.
Once you get down to 1/2 a tank on the indicator, you are probably down around 1/4 of it's total capacity.
zgoo 07-06-2015 09:44 PM
Good to know, but still I thought I would have burned the tanks dry LOL
Steve Zuckerman 07-07-2015 09:39 PM
These boats are relatively efficient. That and some moderate throttle use will net some good mileage.
If you have saddle tanks like most Nordics, they are rectangular. Sydwayz is correct if you have belly tank, doubtful in a Rage.
Regards,
Steve
zgoo 07-08-2015 10:36 AM
I have saddle tanks do it should read right. Big motor in a small boat helps. It cruises at 3200 like butter ;-)
Steve Zuckerman 07-08-2015 11:38 AM
Exactly ;)
