-   Nordic (https://www.offshoreonly.com/forums/nordic-99/)
-   -   05 heat with whipple stage 2 ecu flash (https://www.offshoreonly.com/forums/nordic/351155-05-heat-whipple-stage-2-ecu-flash.html)
DISCO 12-04-2017 09:13 AM
Anybody done this to there 496mag/ho? If so what gains did you see and where?
Ryan00TJ 12-07-2017 07:06 PM
I've had mine since 2015. Whipple has fast turn around time of the PCM. It has ran flawless. Most gains can be felt thru the midrange. The motor feels and revs better at WOT.
https://www.offshoreonly.com/forums/velocity/326298-some-vr1-whipple-stage-2-numbers.html
https://www.offshoreonly.com/forums/general-q/73570-whipple-stage-2-a.html
DISCO 12-08-2017 08:22 AM
What prop are you running and what top speeds are you seeing?
Ryan00TJ 12-08-2017 06:19 PM
Info in the above post. Copy and paste to your browser. Top speed is 75gps @ 4875 rpm with a Bblades labbed 30p Bravo One. 74gps @ 5000 with a 28p Bblades labbed Bravo One.
blownhammer2000 12-08-2017 09:59 PM
You've got some high slip #'s, you've got another few mph in that 28, I had a 25' Nordic rage that ran a best of 78 with a labbed 28, and I'm currently running 83-84 with stock bravo 30's on my current boat, stock HO's
launchpad475 12-09-2017 12:26 PM
Ryan thats the fastest 496 heat I have ever heard of. A Raylar or 525 Nordic won't go that fast, or barely that fast.
blownhammer2000 12-09-2017 04:15 PM
I agree 100%, but I'm thinking hes talking speeds out of his velocity not a heat
Ryan00TJ 12-09-2017 04:40 PM
Yes that's right. Speeds are from a 29' Velocity VR1.
