Fuel tank switch will not switch over to other tank
I have a 2007 Nordic Rage and the fuel tank switch will not switch over. Any ideas what the problem is ?
if its the imco valve...I have the same one in my heat and the electric actuator took a dump last year and I had to replace it...there are a couple fuses on that valve as well...you can buy the ram separate from imco
Is this boat new to you? Can you hear the actuator moving, but not switching? Someone may have pulled the pin out and didn't get it back through the hole in the actuator.
Thanks for the info
| All times are GMT -5. The time now is 03:33 PM. |
