-   Nordic (https://www.offshoreonly.com/forums/nordic-99/)
-   -   Changeing the steering wheel (https://www.offshoreonly.com/forums/nordic/40542-changeing-steering-wheel.html)
01-08-2003 06:15 AM
Has any one replaced their white steering wheel with a colored one and what brand & size did you use? I have a 28 Heat. It looks like you just remove the allen screws on the center hub and remove & replace the wheel but this looks too easy. Is this the correct procedure?
rv 01-08-2003 08:00 AM
I have not replaced ours but I have taken it off before. You are correct in your procedure. Just be careful when you go to pull the steering wheel away from the hub. The center cover piece that sits in the middle of the wheel is loose and will fall out.
Rick
