-   Nordic (https://www.offshoreonly.com/forums/nordic-99/)
-   -   Trailer & tow vehicle tire PSI (https://www.offshoreonly.com/forums/nordic/51101-trailer-tow-vehicle-tire-psi.html)
05-29-2003 06:19 AM
I am going to be towing my 28 Heat 750 miles next month and my question is do I keep the boat trailer tires at max PSI which is 50 and tow vehicle a Chevy Tahoe at max PSI which is 35?
birdog 05-29-2003 06:35 AM
Yep..........Always.......
Indy 05-29-2003 07:18 AM
What Birdog said...
dropthehammer 06-13-2003 09:43 PM
Are you worried about the weight at all over that distance? The Tahoes are rated for 5000 lbs and you are probably a little over 6000....
Chart 06-16-2003 11:13 PM
Are you sure the max PSI on the Tahoe is ONLY 35?!!! If so, you should really check the load rating on those tires.
