-   Nordic (https://www.offshoreonly.com/forums/nordic-99/)
-   -   380 K-planes on a 35 Flame (https://www.offshoreonly.com/forums/nordic/99821-380-k-planes-35-flame.html)
Dean Ferry 04-03-2005 08:44 PM
Has anybody run them on their 35 Flame? If yes, could you please post some pics.?
Thanks,
Dean
BajaBennett 04-04-2005 04:15 PM
Re: 380 K-planes on a 35 Flame
Since you spend so much of your time at idle speed, you really need something to get that bow down so you can see over it!!!!!! :drink:
39 Unlimited 04-04-2005 06:00 PM
never seen a 35 without k-Planes. They are a must in any big water and top end. Max speed 6.5 on drives and 4.5 on K-Planes.
Dean Ferry 04-04-2005 06:29 PM
NG,
I have 280s on my boat now, I'm thinking about putting on 380s.
BB,
At least I can see over the bow :drink:
MD
Linster 04-04-2005 06:40 PM
Gary,
You run the K planes down that much? I have very little experience with them but never use them on WOT. I agree with the 6.5 on the drives. They props blow out at 7. I am going to try the 4.5 on the tabs.
Thanks Linnie
Linster 04-04-2005 06:47 PM
Thanks,
Dean
Dean,
I was in Sarasota last week and went into 5 footers going out of big pass cut. I had the drives totally in and the tabs at 7. Only lost the prop twice. The 280's never went all the way down. I think you will loose all the prop bit since the drives are mounted so high. The key, I think with the Nordics is to keep the drives in and only add enough tab to keep things in line.
39 Unlimited 04-04-2005 06:50 PM
The best way to set your numbers is by digital GPS. At WOT change drive a tab settings to max speed. I found that tabs gave me 1 - 11/2 MPH and completely eliminates chine walking. The only boat I know of using the 380's was a friend who had a supercharged 27 Fountain. The 380's were must over 78 in that thing. Don't see them doing much for the 35 Nordic, could be wrong.
Dean Ferry 04-04-2005 07:12 PM
Good input guys, thanks. I've heard that using 380s on some boats makes the boat really sensitive to level, and it's hard to find the sweet spot! :D
Dean
