| AIR TIME |
05-15-2009 04:31 PM |
why not go from fallriver with mike? its a nice ride about a hour to block at 55 to 65, I think thats what I use to run in my baja just cruise. by the time you drive to judith to unload you could be on block. judith is on the west passage and newport is on the east. early morning will be like glass most times:evilb:. and ride back might kick up before NEWPORT BUT ONCE IN THE BAY its 2 to 3 footers if it kicks up. well looks like I will be in the water by july in what not sure:evilb:. looking at some running boats and non, most likely will put the baja together with blower motor and buy a used hull looking at a few a cig 28 two, a cig 27squadron,hustler 32, new would be this winter joker 28/sutphen 27 or32 theres a used 32 but it has power and drive so I might ask if they will unload it minus the power and drive, banana 28 put they want to much for a hull thats from the 70s and 80s not sure if it would run out of hull speed?? y2k has a new new step bottom same as sutphen and joker,if I can get one of the builders to work with me on price and I would bring the boat to any boat shows,races, pokerruns and test the different horsepower in the boat I could do 5 different combos from 600 to 1200 to help them have speed readings for customers. superboat would already has had the konrad on there boat. so the only ones it could help would be joker maybe and the new sutphens and Banana but they wantfull retail it looks from what they charge for twin OBs to what they charge for no power.
