Db Testing???
Is There A Sound Level Restriction On Senaca?? And Will It Be Enforced At The Poker Run?
Re: Db Testing???
Proman
There is a 90 db. level on Seneca as well as the rest of the State. However, during the Poker run the SPBA obtains a Federal water way Regatta Permit, which indeed grants us permission to run with-out mufflers for the duration of the wknd. This is the same permit that is required to hold a racing type event. The only thing you should be getting nervous about is that incredible Auction on Sat. night. :drink: See you at the run! Bill |
Re: Db Testing???
Is the 90 db measured at idle or at speed?
How far away is the db meter placed? |
Re: Db Testing???
RLW
The 90db. test is done at idle. The db. unit is placed approx. 3ft. back (from transom) and 3ft. up (from swim platform). There is a 2% +/- margin of error allowance. I hope that answers your quest. Bill |
Re: Db Testing???
Bill,
Thanks for the reply. Hopefully get over to Seneca this year to check out your club. I spend alot of time on Canandaigua Lake. I have met the Nader Brothers at a friends house, here on Honeoye Lake. Russ |
Re: Db Testing???
RLW
Hope to see ya'. The Naders boys are good bunch. We have a drink or two (...or three, or four) on occassion. You should make it over for the Pirates Run. I think you might have a good time. Bill |
| All times are GMT -5. The time now is 06:47 PM. |
