-   Northern Illinois Offshore Club (https://www.offshoreonly.com/forums/northern-illinois-offshore-club-137/)
-   -   Engine rebuilders (https://www.offshoreonly.com/forums/northern-illinois-offshore-club/122944-engine-rebuilders.html)
Bam 02-19-2006 09:31 PM
Engine rebuilders
Hey guy's, Bz's buddy "Anger Management" here. Looking for a engine rebuilder to freshen up my 525sc's possibly. Any recommendations from anybody??? Have some issues going on with leak down vs. compression tests. Any help would be nice. Thanks B-rad
Payton 02-20-2006 06:54 AM
Re: Engine rebuilders
RPM , Riss Performance Marine.
Downtown42 02-20-2006 07:53 AM
Riggs Marine Fondulac WI
hi Brad.
10x 02-23-2006 03:11 AM
Don't worry about the compression. Double check the % of leakdown. If you're over 15%, then you might want to start looking for the problem.
Also, check to see if you're having a water leaking issue. Were any of the spark plugs wet from water, or have any rust on them?
The last thing you want to do is rebuild the engines if there's only a minor problem and the boat is running fine otherwise.
Frank
Ms PatriYacht 02-23-2006 10:52 AM
Ask Mark Smith for a reference :D
Ms PatriYacht 02-23-2006 10:53 AM
Not sure if you friend can get to Grand Rapids but a lot of people speak highly of Dave Wesseldyke (not sure of the spelling)
Quiet Storm 02-23-2006 12:10 PM
RPM rebuilt my engines and they run great.
Wally 02-23-2006 02:38 PM
Ive had good luck with Fast Times in Morton Grove... :)
mike11 02-23-2006 07:05 PM
Give us a call we can help you.
Thanks Mike
Roccard Marine Engines
www.roccardmarineengines.com
[email protected]
570-956-2840
chaineddown 02-23-2006 09:20 PM
Powersource in Fox Lake, Il has done alot of engines for me and I,ve never had a problem. ( I'm a Merc. mechanic)
