Turn markers?
Old 01-20-2006, 07:46 PM
TYPHOON's Avatar
Default Turn markers?
Is there a better way to identify the turns. As crazy as it sounds that a 50' boat is at turn 1 and not everyone can find it is crazy. I am one of those racer's that gets confused with patrol and safety boats on the course from a distance. Point Pleasant last year was a good example of the problem. Many veteran racers had a hard time finding the pins. At the drivers meeting it looks like you would have to be brain dead not to have a handle on 4-6 turns with 50' boats with flags. To be honest the start finish boat is not always easy to find as well. It seem's there in always a spectator boat or large patrol boat in the same area. Is it just me? Dont be embarrassed to admit it if you have the same problem. It will only make it safer for everyone. I have watched many races where a Supercat has cut the field off by accident only because he couldnt find the pin.
With that being said would it help to have a smoke flair at turn 1 at the start or have the turn boats have strobe lights or fly small hot air ballons with advertisers on the turns. It just makes sense on these 5 mile courses. I know we all have a campus and there used to be navigators but those days are gone. Any suggestions we can propose?
MD
TYPHOON is offline
Old 01-20-2006, 08:40 PM
JohnS's Avatar
Default Re: Turn markers?
I'd like to see strobes on turn pins. There is no mistaking a flashing light in the distance.
JohnS is offline
Old 01-20-2006, 08:45 PM
Enjoy the show
Ron P's Avatar
How about if we light all the turn boats on fire at the start of the race, would that help?
Ron P is offline
Old 01-20-2006, 08:50 PM
Then we would have the drift of smoke onto the course. The bright strobe lights double up the pins bigger turn boats or a larger flag?
JPD Motorsports is offline
Old 01-20-2006, 08:53 PM
Enjoy the show
Ron P's Avatar
We actually have stobes for all turn boats. They were only used to signify an accident after the turn.
I actually like the idea of flying a small blimp. Wonder how much of a pain in the azz they are to blow up and deflate.
Randy, get a blimp sponsor. Car dealers should like that. We need 5 of them.
Ron P is offline
Old 01-20-2006, 09:05 PM
Charter Member#203
Pete B's Avatar
Received 16,090 Likes on 4,207 Posts
I know we all have a campus [QUOTE]
That would be compass, besides starting on time and doing the parade lap may help as well!!!!
Pete B is offline
Old 01-20-2006, 09:26 PM
BRAD SCHOENWALD
bcschoe's Avatar
I have suggested using modified “High Flyers” in conjunction with the existing turn buoys. These are buoys used by commercial fisherman to mark long line nets. They can be rigged to be as high as 20 feet with pennants and or strobe lights. They are not expensive as you buy the components and rig them to suit your needs..
bcschoe is offline
Old 01-21-2006, 06:43 AM
Hauling Trash's Avatar
Thats what the OPA use`s for there turns.
2014 OPA-APBA National Champion Class 7 .Hauling Trash 725.
Hauling Trash is offline
Old 01-21-2006, 06:58 AM
AugiePensa's Avatar
Big, REAL BIG Turn Markers
P4-13 Team THE JERSEY BOYZ OFFSHORE POWERBOAT RACING, OPA/ SBI/APBA/UIM. PRESIDENT: THE JERSEY BOYZ , VICE-PRESIDENT: OPA RACING, THE GREAT SOUTH BAY RACING ASSOCIATION. WAZZUP RACING ENGINES
AugiePensa is offline
Old 01-21-2006, 10:06 AM
LarryD
the advent of GPS has made this not as much of a issue also now that oss lets us run the course the day before I write the compass headings down than draw the course on a sheet of notebook paper with the headings in black magic marker and tape it to the dash ( unless it is a simple course if there is only one or two hard to find pins I just remember the headings) and the gps is back up we set ours so it plots your course then if you are not sure you can glance down to see if you are on the line.
all that being said turn balls flying a balloon or blimp would be great they can't be too big
however for randy there is a simple solution just follow us we will lead you around the course and while you are at it you can block will for us
Larry SVL#5 wildride
Quick Reply: Turn markers?
