496 E-Top Headers
CMI’s 496 E-Top Headers are a direct Mercruiser replacement for your 496 Mag or 496 HO engine. There is no need to purchase additional custom tails. This is a true plug and play system.
These 496 E-Tops are mandrel bent and formed from high quality 316L grade material. The headers offer more water jacketed protection than your stock exhaust can provide. CMI uses the same high quality semi-automated process on these headers as with the entire product line. These headers are fully post annealed to reduce stresses built up in the header during the manufacturing process. Sophisticated engineering leaves your stock oil lines in place and only requires relocating your oil filter with a supplied bracket. These 496 E-Top headers are easy to install with step by step, do it yourself instructions using Mercury supplied engine schematics. This kit is price competitive to other aluminum/stainless manifold systems. The 496 E-Top Header kit introduces CMI’s new low cost satin stainless finish or choose from the classic polished stainless finish. · No custom tailpipes required, the 496 E-Top is designed as a direct replacement for your stock exhaust · Infuses the competitive racing look to your stock engine · 1 7/8" id primary to reach peak horse power and torque · Works on drive centers as narrow as 34.5" · Cool collar patented flange designed to eliminate the risk of getting water in the motor by the head flange · No need to relocate the stock ECU, making installation quick & easy · Exhaust water temperature bungs installed as standard equipment · No cast parts to crack, all CMI collectors are forged from American made stainless steel For more information, call Custom Marine at 920-720-4225. |
| All times are GMT -5. The time now is 10:19 AM. |
