LED Position Indicators compatible with NMEA 2000 and SmartCraft Devices
https://ci6.googleusercontent.com/pr...mi_eheader.jpg
The LED position indicators eliminate the need for mechanical 33C cables which are typically used for drive and tab indication. These cables have a tendency to deteriorate, will fail over time, and are inaccurate due to lost cable motion. With the Livorsi LED indicators, mechanical cables are replaced by more reliable network wiring that allows 'plug n play' connectivity into existing tab or drive position sensors. Another valuable feature is the single middle green LED. During calibration, this LED display can be set to indicate 50% of actuator travel, fuel level or whatever you are monitoring. What makes it so special is that it allows you to establish the optimum running angle - or sweet spot (not at 50%), to dial-in the vessel for optimal running efficiency so the novice boater always runs at the correct trim. If you do not have drive trim or tab sensors, we have the solution. For applications or retrofits that do not have electronic position sensors, Livorsi can provide you with a mechanical to electronic converter solution Summary of Features
Indicator Pricing begins at $714.00 For more information please call visit our website, call Livorsi at 847.752.2700 or email [email protected]. |
| All times are GMT -5. The time now is 01:42 AM. |
