Minimum opa # size ?
Been looking thru the rulebook & cant seem to find it.
Anybody know off hand what size the racing #s on the boat need to be? Thanks, mike |
Page 37
6.All boats numbers shall contain not more than three (3) digits and shall range from number 2 through 999. Numbers shall be vinyl or paint in black vertical block lettering over a white background. If applied to a white hull, a black border must surround them. The minimum height of each number shall be eighteen (18) inches, minimum width shall be thirteen (13) inches, and minimum stroke shall be three (3) inches. Minimum spacing between each number shall be four (4) inches. This is from the 2011 Rule book, havent seen the 2012 rules yet, but these should help you get in the right direction |
Thank you
And your number for class 6 has to be 600-699.You can check with OPA to see what is available.
Here are team numbers that have been used the past 2 seasons:
601 F&R Racing 605 Reindl One Design 606 Lock'd Up Bandit 607 Akula 611 Joker Powerboats 613 Bad Newz 619 PFE Racing 623 Country Service 626 Maxed Out 633 Wazzup II 644 Knot Guilty 650 Nopper Marine 669 Tyler Crockett Marine Below was also used, but only in a local race: 618 Rip It Up (Raced 1 race in 2010) 699 Scarab (Raced 1 race in 2010) "01" is usually reserved for the National Champion who can opt-out to not use it |
Got 617 on hold. Turning paperwork in hopefully next week.
Thanks |
| All times are GMT -5. The time now is 09:11 AM. |
