Lead Bags
Hey guys we are need of some lead bags for a SVL. Does anyone have a line on some or even used ones laying around.
Thanks |
Rotometals.com
I don't know about lead bags but I have plenty of 1/8" lead in rolls that you can make any kind of bag you'd like out of it. Prob have 600 lbs of it. We make lead rooms at work all the time. Also I'm local to your guys shop.
go to a hunting store, get 25lb shot bags, I cover them in vinyl
Bolt some flywheels to the stringers up front. Works great, no mess.
I have Stanless boxes that are filled with shot that you bolt to angle iron in different locations around the boat. You can adjust the weight by removing or adding shot. Think I have 4 of them.
Originally Posted by Karaokemike
(Post 3915425)
Hey guys we are need of ad bags for a SVL. Does anyone have a line on some or even used ones laying around.
Thanks |
Originally Posted by fastedy
(Post 3915823)
http://www.wayfair.com/Square-Perfec...FcJo4Aodm2AAjA With as weight sensitive as these SVL's are you need to have your weight movable over the past couple of years I have made 5 lbs, 10 lbs, 25 lbs, and 50 lbs bags CG is a science Mikey, good luck!! |
I used 50lb dog food one time in a pinch
(Post 3916578)
| All times are GMT -5. The time now is 04:39 PM. |
