Prop Setup
What would your thoughts be on the correct prop setup for a:
37' single step 620 hp side by side motors bravo's with no boxes |
these were set up from the factory with Hydromotive 4 blade thru hub props, in the 27 - 28 pitch range with a 1:50 gear
Originally Posted by 32fever
(Post 2623077)
all 37 side by side were set up spinning out for maximum transom lift...the 37 single strp carried the nose naturally
| All times are GMT -5. The time now is 05:39 AM. |
