-   Outerlimits (https://www.offshoreonly.com/forums/outerlimits-89/)
-   -   Towing in rain? (https://www.offshoreonly.com/forums/outerlimits/256996-towing-rain.html)
Sydwayz 07-05-2011 01:08 PM
Originally Posted by wgg (Post 3443348)
use some galvanized self tapping sheet metal screws If you dont use galvanized they will rust
No SS? :D
http://www.dr-shrink.com/tape
SS930 07-07-2011 08:09 AM
Originally Posted by OL40SVX (Post 3443371)
Outerlimits full covers go right to the bottom of the boat with straps about every 6ft. We have a full soft sock that goes on first. They work great and don't hurt the gel or paint. We never tow with a cockpit cover on.
Originally Posted by richanton (Post 3443423)
That sounds like exactly what I need, I was getting ready to have one made. How do I get one?
Rich,
I have this factory setup (although mine has the straps about every 3'). It's a mixed bag IMO.
The pros are the sock has the potential to protect the paint from movement of the main cover. The cover itself is very secure and would be perfectly fine for towing... also seals the boat very well from the elements. No fears of it leaking water either.
The down sides are... Unless you're working in a clean-room environment, that giant sock picks up dirt and debris almost as well as a Swifter (which obviously can be a bad thing). The main cover is pretty heavy and cumbersome, and getting the two on togher can be a PITA, especially if you're by yourself. It's not a two minute ordeal and I promise you'll break a sweat putting it on, haha.
If you're looking for a cover for towing or even long term storage, this factory cover is a great setup. It helps if you have a couple of people to install it though. If you're looking for a full cover to quickly and easily throw over the boat during the week for some protection from the elements, I'd look elsewhere!
Just my 2 cents.
SLOWRIDE-388 07-07-2011 06:58 PM
Thanks again for all the great helpful hints. Did not end pulling it so will just keep all the great ideas for the next time.
richanton 07-07-2011 08:57 PM
Originally Posted by SS930 (Post 3446778)
Rich,
Just my 2 cents.
Thanks for the explanation, that does make sense. I'm having a new cockpit cover made (FYI, don't use that Starbrite waterproof spray on brand new canvas, it stains) and I'll probably also have him make me a mooring cover that covers the deck down to the rubrail and around the exhaust tips. That will provide some protection while the boat is on the lift and keep it relatively clean while it is on the rack. Plus, I can get it on and off myself. If the boat will be sitting around for a while in storage, or if I need to trailer it, then I can use the full cover.
Does the full cover set-up cover/protect the drives?
SS930 07-07-2011 10:05 PM
Mine does not. In fact, it stops at the back of hatch and is the only place I feel it's lacking as far as protection goes. With that said, you would not want it to cover the back if it was to be used for towing, so that's probably what the designer had in mind...
I might buy a cheap full length polyester cover for weekly duty, something light weight to keep the boat from being exposed, yet very quick and easy to install. I'm just not sure if I can stomach the poor fit! :D
PokerRun388 07-07-2011 10:32 PM
Good Points Scot....:drink:
richanton 07-08-2011 06:34 PM
Yeah, I thought about doing the same thing. Washing the boat before you use it and after you use it gets old.
