-   Outerlimits (https://www.offshoreonly.com/forums/outerlimits-89/)
-   -   Set up help! 37 OL (https://www.offshoreonly.com/forums/outerlimits/267235-set-up-help-37-ol.html)
drpete3 12-15-2011 01:22 PM
Set up help! 37 OL
Last year I got the new to me boat and here were the results I saw before I had a major melt down. Running 34p bravo 1 props w bmax drives 1.26 ratio and imco lower. Best I saw was 5050 Rpm and 97 gps. It was dead flat water 3/4 tank of fuel and 5 people. If you calculate that w the Bamm slip calculator its 25%. Engines were about 925 hp ea.
Had a valve go and was down as of June 25th. Engines are getting rebuilt and Im going w about 725 hp per side. Where should I start w props? I was thinking of trying a 30p 5 blade and maybe even 28's. I want to get the slip numbers down into the teens and still need to talk to the builder as to max rpms I should be lookin for but wanna hear some thoughts.
jbadd90 12-15-2011 01:46 PM
on our 37 with 575 stag setup we ran 32 5 blades
kreed 12-15-2011 03:33 PM
I have a pr of 28P Hydromotive 5 Blades if you decide to go that route.
POWERPLAY J 12-15-2011 04:29 PM
Call Dan. He is very knowledgeable and has his dialed in quite nice.:)
drpete3 12-16-2011 06:41 AM
My issue is that I dont want to change the 1.26 drive so my pich is going to be fairly different.
SS930 12-16-2011 09:07 AM
Your initial setup seems like it was out of whack to begin with. I'd guess a 24p-26p for a starting point.
overlimits 12-16-2011 05:06 PM
with that gear ratio, id start with 26's & go from there
endeavor1 12-17-2011 06:45 PM
Are you sure its a 1.26? All the Bmax's ive owned were 1.3. Not saying they dont make a 1.26, just have not seen one.
sv43BB 12-17-2011 09:41 PM
You need to change gear ratio. Way to much slip. Try and borrow props and recalculate slip. Maybe drives to high or over trimmed. Try larger diameter.
LV 12-18-2011 07:34 AM
Do you have stand off boxes?
