-   Outerlimits (https://www.offshoreonly.com/forums/outerlimits-89/)
-   -   Access to step down pump? (https://www.offshoreonly.com/forums/outerlimits/281392-access-step-down-pump.html)
JoeD 07-24-2012 05:44 PM
Does anyone know how to access the step down bilge pump for the Head/shower enclosure on a 37 Outerlimits?
richanton 07-27-2012 09:34 AM
Not sure what you mean, you lift up the step on mine and the pump is right there.
tgersx 07-27-2012 11:03 AM
Depends if your boat is side by side seating or not, if you cabin door is offset the way mine was with side by side seating. They had a pump under the sink in the bathroom and there was a hose that went to the floor and with a float to turn it on.
Pro1 07-27-2012 11:26 AM
sawzall lol
JoeD 07-31-2012 05:03 PM
Yes mine is side by side with the cabin door off to the left,my pump is running but not pumping ---sounds like its mounted under the raised area the head is mounted to ----I might need to cut an inspection hole and put a hinged hatch.
