-   Outerlimits (https://www.offshoreonly.com/forums/outerlimits-89/)
-   -   Fuel System Upgrades, 37 Stiletto (https://www.offshoreonly.com/forums/outerlimits/332684-fuel-system-upgrades-37-stiletto.html)
Full Whack 12-10-2015 07:24 PM
Update, purchased a pair of Aeromotive bypass regulators from Smokin Gun (Gordon)! What would you guys recommend for line size? The pumps are 10AN inlet and outlet, I believe the regulators are 8AN inlet and outlet with a 6AN return? Not positive on that though.. I was going to pull 10AN out of the tank to the pumps and 8AN from there trough the regulator and up to the carb? Or should I do 6AN to the carb? And best place to buy AN fittings and hose? I was just going to use Summit but maybe here are cheaper alternatives? Thanks!
Justin
Griff 12-13-2015 09:29 PM
Go 8AN to the carb
wildthing357 12-17-2015 06:02 AM
1 Attachment(s)
[ATTACH=CONFIG]548974[/ATTACH]
Found a old pic of your boat.
Bullhead 12-17-2015 03:16 PM
Is that boat on a lift?
wildthing357 12-18-2015 05:58 AM
Think it was pushed out for a picture.
TomFTM 12-20-2015 10:47 AM
Justin
I checked the pick ups in my boat (37 Ol 95) and I have 4 bungs in the tank. U will have the same most likely. U will not need to change pick ups as they are 1/2 npt on the elbow out of the pick up. There is no way u need bigger than 1/2 npt with the power u are running. I run 150 + more hp per motor . Never a fuel pressure problem and I run 140 gph Holley mechanical 1/2 npt in and out of pump. I'm running -8 from tank to pump and -8 to distribution block and -6 to the dual 850 demons . 557 tall decks with 1071's.
Full Whack 12-20-2015 05:31 PM
This is great info!! So there are provisions for returns then by using the two other bungs? Does your setup utilize returns? Thanks for the info!
Justin
TomFTM 12-20-2015 07:23 PM
Justin
Yes u will have two extra bungs for returns. I set my system up and I do not run returns .
