-   Pantera (https://www.offshoreonly.com/forums/pantera-39/)
-   -   Drive Indicator Actuator (https://www.offshoreonly.com/forums/pantera/107152-drive-indicator-actuator.html)
tomcei 03-29-2006 05:23 AM
Re: Drive Indicator Actuator
I'll check that out.
Elite Marine 04-11-2006 10:29 PM
Anyone find the Merc Actuator cheap yet? i need one still!
cobra marty 04-12-2006 04:51 AM
What does that merc actuator look like?
tomcei 04-12-2006 08:20 AM
I called K.E. and steve is looking in to this for me. I told him about my set up. He should have a solution soon I hope.
Elite Marine 04-12-2006 08:02 PM
They look like the Blue Water, but have a rod that sticks out as you trim up. Jo can get them, but they are like $ 300.00 or more. There has to be some source for these at a little less $$.
Bam sells them too.
Elite Marine 04-15-2006 04:26 PM
Anyone?
tomcei 04-15-2006 07:53 PM
Livorsi has it I was told. I will get the part # and link. Aprox. $180.00.
Part # AMBHPS.
Steve at K.E. said It will solve the problem. It is suppose to pull the cable when the drive is lowered and push the cable in when trim'n up.
Fred at trick might have it or might be able to confirm.
Elite Marine 04-16-2006 12:28 PM
I searched their site with no luck. That part number is for the type that bolts to the electric sender. I need the type that clamps on the ram.
Keep me posted, thank you.
