Props
First, took the 24 out for the last weekend of the year. were able to find some rough water, and there were some large party liners out, so hit some 4+ waves. Aired it our a couple times and barried the bow. Looked over at my wife and she had water all over her. She also had a huge smile on her face. Getting use to it, and it is running great. We run, on average, 65-70, and we still have some left. Can't wait till next summer.
Now to the props. We have a 27 pitch on there now. i also have a 25 Pitch mirrage plus. What are the major differences? What type of speeds should I see with the 25. I am thinking of switching next summer. Will I lose some low end with the 25? |
Re: Props
Court you need to give us some gps speeds and rpms. Is the 27 a Mirage Plus? The 25 mirage plus should be able to hit 75 - 77 easily if the motor has the torque to turn it at 5200 or 5300.
The M+ has some more cupping and slightly different blade geometry than the std Mirage and runs about 1.5" bigger than stamped , about 200 rpms less than a std mirage 25. Guys have found the std mirage to be a little faster than the M+ because the blades are a little thinner. M+ has better trim control and holding grip in turns and planing off due to the added cupping. Good Luck, Chris |
Re: Props
Thanks Chris. We have about 450hp, might be a little more. I think it is a standard 27 pitch. We are running about 65 MPH without trimming up. Trim it and get up to about 70 and are about 4800 rpms. Might be a little higher. Could trim it more and get more speed, but it starts getting lose on me, and I need to get use to it more. I might need to adjust the throttle as well, as will not go higher. Can get rpms up more as I trim it more, but I do not think I have hit 5000 rpms yet. I think I am starting to get some prop slip as I trim it more and more. When I pull the boat i will have to look at the prop I have on there.
What would anyone recommend for a prop next summer. Stick with a 27, got the 25+ or purchase something else. |
Re: Props
How high on the rpm range do you want to turn the motor to ? With a "real" 450 HP you should run in the 74-76 MPH range.Is the motor a 502 CI ?
JO |
| All times are GMT -5. The time now is 08:13 PM. |
