-   Pantera (https://www.offshoreonly.com/forums/pantera-39/)
-   -   stand off/ set back on a Pantera (https://www.offshoreonly.com/forums/pantera/148196-stand-off-set-back-pantera.html)
tomcei 12-31-2006 10:26 AM
I was wondering how or what to expect in handling when the out drive is moved rearward on the single 28/.( no notches, standard transom, full cabin) I thought about posting this in the tech section, but quite frankly i'm only concerned with the Pantera and not other boats (in general) I'm trying to get opinions/ advice.
For instance prop slip, cg , and how to determine prop depth
starting points.
I know Kirk is right in the middle of this. His upgrade has me
thinking of changing myself.
Question: If you installed a #6 would you set it back to keep the mrt in the same location and put trany in box?
OR would the extra weight of the 6 hanging back that far not be so good.
I have(I think) room to move mtr foward and mount 6 gimble to transom.
My thoughts are to move mtr to help maintain the balance I already have.
If a blower was in the future would the snout be too close to the engine bulk head?
Also would you want the prop depth on the #6 to be relatively the same as the Bravo?? I understand the 6 to be a surface drive. If this is true how would bow lift be effected? ( I realize it wouldn't be as unforgiving as the arneson)
If you guys could lend some advise it would help me keep from making a mistake.
Has Jo ever installed a #6 on the 28?
Thanks,
Tom
B-Stubb 12-31-2006 04:00 PM
Re: stand off/ set back on a Pantera
Im puting a Imco box on my 28 this winter and hope to gain some handeling . I have a good baseline and should be able to answer that question by the first of Feb
Elite Marine 12-31-2006 04:13 PM
1 Attachment(s)
I believe Von Bongos 28 has a box and no notch. It's actually Cattitudes boat now. Both have said they had no issues with the stand off box, that's why I am going with the box.
I considered a #6, but they are very heavy and nobody has installed one on a 28 Pantera.
I pulled my engine so moving it forward was not an issue, but I like the space afforded by having the engine back. I pulled my balancer in the boat before with no issues.
It is very nice to not be tube locked when working on the engine. What's the forward distance in a singe? I pulled my motor so I can't measure. Maybe someone elese can tell us.
I think a tranny takes up at least 8". Here's my old engine, I don't think I would like to take 8" from the front of this set up. It would be too tight.
Cattitude 12-31-2006 04:16 PM
mines the 7" ITS, Joe set it 1/2" higher, 17.5" X I think, works fine
MIAMIBOYZ 12-31-2006 05:37 PM
Make sure Tom if you decide to mount a box that it has the degrees to match your transom. A number six will be my next investment.
Elite Marine 12-31-2006 06:55 PM
Thats true Albert. The transom angle on our boats is 11 degrees whereas most offshore boats are 13 degrees. That's why Konrad is making a wedge adapter to square the drive with the transom.
You would need to do the same thing.
tomcei 12-31-2006 09:54 PM
If I go the #6 route I will make the transom assmy. fit correctly. Thanks. I'm most concerned w/ the X demintion.
Kirk, I agree that tight spaces make for frustrations while working on the engines.:(
I have a decent set up now for pulling the engine. I made a tall steal A frame that comes apart in 3 pieces. I plan to make several changes to the bilge to make pulling the engine easer/quicker.
If feed back is good with the weight and handling I may keep engine in the stock location.
IRONMAN 01-01-2007 03:00 AM
Here is my thoughts Tom as I had the most awesome opportunity this summer to run in both my single and Sonny's twin in the same day. I do not think that with any single 28 you can have too much weight aft because even with the twins the boat does not seem too stern heavy and handles great, now the 525's should be a little lighter than some other twin packages because they have aluminum heads and stainless exhausts but a pair are nowhere near as light as even a blown iron head single with a #6. Now don't get me wrong because a #6 on a 28 are what my dreams consist of, but I think in reality a good quality shiftable drive (Teague Platinum or equivalent) or at most a Konrad, #3a or #5 (in that order) would be fine with pleasure use and decent power 750 to 850+. Kirk is definately doing it right with the Konrad and the quad rotor engine I guess it is just defining what your goals are and going for it.:D
tomcei 01-01-2007 08:02 AM
2 Attachment(s)
Chris please tell me you got up early and arn't still up from the new yrs eve blow out:eek:
My objective is simple. I don't want to worry about breaking a drive when I go play. I also want to add more pwr. I'm not looking for extreme top end mph. I want maxum excelleration and hard core duribility. I love jumping the boat and with that said it's only a mater of time before I mess up on the stick and have to be towed in and spend $ again.
I hate the idea of not being able to add pwr because the drive limitations.
It is just crazy, I used to have a car that had a nine inch in it and used to rev. 5-5500rpm before a launch and it never broke.
tomcei 01-01-2007 08:04 AM
wow those pics sux. they looked good on the pc
