-   Pantera (https://www.offshoreonly.com/forums/pantera-39/)
-   -   Two batteries (https://www.offshoreonly.com/forums/pantera/152012-two-batteries.html)
Courtholl 02-22-2007 12:42 PM
Two batteries
we currently only have one battery in our boat. Want to put another one in there for security on the water, etc. Do not listen to radio when not moving, and want to be able to sit and listen to radio, etc. We have the switch installed and the one battery already in the boat. I would need to find a place for another battery and then wire it into the switch (bat 1, 2, off, etc.). How hard is this to do. Have not been in the boat all winter, and I am not astute at this stuff as most of you are.
Also, I want to put a trim switch on the throttle, how hard is this. I do have a shifter. i think it is gafrig.
Dude! Sweet! 02-22-2007 12:51 PM
I have a battery box on either side of my motor up against the transom on the outside of the stringer. I assume it's mounted through the stringer, but Ironman would know the answer to that and would also be very helpful with your other question.
Sydwayz 02-22-2007 02:03 PM
With a single engine boat, you may want to put the batteries on the same side that rides high due to prop torque. Does your boat have this issue?
www.trickmarine.net has just about every battery mounting option available you could want.
Dude! Sweet! 02-22-2007 04:53 PM
I haven't noticed a major prop torque issue, but then again I run about 250# of ballast in the driver's seat...
rchevelle71 02-22-2007 10:48 PM
I made a plate to rig all of my stuff on in the bilge, 2 batteries, switch, and trim tab pump. But then again, I dont have a motor in mine, its a weedwacker on the transom:D
Elite Marine 02-23-2007 07:45 AM
Split the batteries up one on each side. I had that set up in my 24 and it was fine.
ziemer 02-23-2007 08:27 AM
Trim switch is pretty easy. You can tie into the dash mounted trim switch vs. running all the way back to the trim pump. Just remember, green like the grass is down and blue like the sky is up. ;)
I've got 2 batt's in mine and they are up against the bulkhead behind the rear seat and one is one each side. I'll be out in it this weekend, if I remember I'll snap you a picture. :cool:
TexomaPowerboater 02-23-2007 11:59 AM
My parents used to have an old Sea Ray - 24 cabin cruiser. We used to sit outside floating just in eye sight from the lakehouse and play that radio all night long. Before I had ever had a battery go dead while under way I spent an entire summer running that boat and listening to the radio all night and all day with out charging it up once. The battery didn't go dead until the next spring when we took it out for the first time. Parents new Sea Ray has two batteries, I have never had to switch to the other one. Very Small stereo in both boats.
rchevelle71 02-24-2007 10:51 AM
YUP,
that is how mine is, with trim pump, and batt switch in da middle.
ziemer 03-05-2007 12:54 PM
2 Attachment(s)
Here's a couple of pics of how mine was setup. ;)
Stormrider 03-05-2007 02:36 PM
wow, the bilge is still lookin good.
ziemer 03-05-2007 02:44 PM
I actually thought you might say it looked dirty. :eek: :D :D Put a new impeller and housing in this weekend and I'm getting ready to change the oil so I haven't cleaned it up yet. :drink:
Stormrider 03-05-2007 03:48 PM
how's the paint holding up?
did it myself... :)
ziemer 03-05-2007 04:26 PM
did it myself... :)
Looks good, I don't think it's peeling up anywhere, and it's still nice and white (except where's it dirty.:D )
