-   Pantera (https://www.offshoreonly.com/forums/pantera-39/)
-   -   Prop slip on twins (https://www.offshoreonly.com/forums/pantera/157120-prop-slip-twins.html)
littledcsrodshop 04-30-2007 04:46 PM
Prop slip on twins
What kind of prop slip #'s are any of you guys getting with Twins in a 28 & what props. Thanks , Scott
IRONMAN 05-01-2007 06:49 PM
Did you change your mind on cutting the center stringer Scott?
Could be interesting with twins again.
The one twin 28 that I got a ride in had stock bravo1's and was right at 10.5 percent slip
littledcsrodshop 05-01-2007 07:53 PM
Thanks Chris , I knew it should be quite a bit lower than a single but just no shure how much.
The twin thing is up in the air for now , As you guys have probably figured out by now I like to keep my options open , So we will see .
