dump valve
I'm going to install a water pressure dump valve. Anybody else usng one? any pics?
thanks, Tom |
1 Attachment(s)
I installed one after my sea water pump. Here's a picture. Although I think with my relief line from the rear of the block and the CMI Headers I dump a little too much water. I only get about 10 - 15 PSI max water pressure.
I think the valve is set at 35 PSI. |
Thanks Kirk. I plan to install one after my cooler and before my crossover. I believe it is set for 24lbs.
I changed my bypass line and still have too much pressure. Maybe this will do the trick.I'm ready for some wot runs:cool: |
1 Attachment(s)
I installed one before the crossover,but after oil cooler.The water pressure stays between 19-25 lbs .
3 Attachment(s)
Well ,I finally got mine mounted up. I was going to mount it on the inside of the stringer to hide it, but it woud have been a nightmare plumbing it. I decided to take the easy way out. I hated to mount something else on the transom. It seems that the more stuff you need the less clean the install looks (too cluttered)
If all else fails I can use it for a wheel stop:D , it's big enough. I buttoned it up early this morrning, took it to the lake and 1/3 the way there the bottom of the sky fell out. Crappy weather today. I'll try again tomorrow. |
| All times are GMT -5. The time now is 03:50 AM. |
