Performance numbers 24's, 28's, 35's and 36's - What are your top speeds?
Are you guys up to this? I think a thread with performance numbers from the different size Panteras would be something we all could benefit from.
Please fill in you #'s! Model (24/28/35/36): Year: Layup (pleasure/race): Weight (empty): X-dimension: Notch (Y/N): Number of engines (1/2/3): Engine make/model: Displacement: Power: Torque: Drive: Setback (Y/N/length): Nosecone (Y/N/which one): Gear ratio: Prop (model, size, labbed, etc): Max speed: RPM: Test conditions (wind, chop, etc): Load (fuel, crew, etc): Comments: |
Model (24/28/35/36): 28
Year: 1999 Layup (pleasure/race): Race Weight (empty): 4050lbs X-dimension: 19-1/2" (2-1/3" prop shaft to bottom, 5-1/3" cavitation plate to bottom) Notch (Y/N): Y Number of engines (1/2/3): 1 Engine make/model: BBC 509ci SCI Displacement: 509ci Power: 825HP@5800rpm Torque: 815ft-lbs@4000rpm Drive: Bravo One XR Nosecone (Y/N/which one): N Gear ratio: 1.50:1 Prop (model, size, labbed, etc): Bravo 28" non labbed Max speed: 88mph RPM: 5800rpm Test conditions (wind, chop, etc): Windy, 1/2-1ft chop Load (fuel, crew, etc): 300lbs of lead attached to stringers and bulkheads in the bow, 2 people (350lbs), 50gallons of fuel. Comments: Had ~25-30% left on the stick due to low fuel pressure. |
can i play too? i have a 36' tho.
Originally Posted by joepaws
(Post 2323029)
Tomas! Great idea! I'll update later today with my old info and friday with new info. Very cool!
Model (24/28): 28
Layup (pleasure/race): Pleasure Weight (empty): 6200 X-dimension: Notch (Y/N): No Number of engines (1/2): 2 Engine make/model: 500EFI Displacement: 502 Power: 670 x 2 Torque: Drive: XR's w/ Sportmaster shorties with 1" spacer Nosecone (Y/N/which one): Gear ratio: 1.5:1 Prop (model, size, labbed, etc): Hydromotive P5x - 30" Max speed @ WOT: 96 RPM:5500 Test conditions (wind, chop, etc): 1' chop- 85* Load (fuel, crew, etc): 90gal w/ 3people @ 550# Comments: Whipple Stage 2 superchargers ( Whipple claims 745hp- I say 650-670 real hp) |
Old Data with 525 -
Model (24/28/35/36): 28 Year: 1996 Layup (pleasure/race): Pleasure (yah, baby!) Weight (empty): don't know feels "athletic" though... X-dimension: propshaft centerline is 6" below the bottom Notch (Y/N): Yup Number of engines (1/2/3): 1 Engine make/model: Merc 525SC Displacement: 454 Power: estimated 550 Torque: NFI Drive: Imco Extreme SC Setback (Y/N/length): N Nosecone (Y/N/which one): N Gear ratio: 1.50 Prop (model, size, labbed, etc): Bravo 26 slight cup/rake Max speed: 66 RPM: 5200 Test conditions (wind, chop, etc): light chop <1' Load (fuel, crew, etc): full tank (100ish gallons) 3 people 700# Comments: More to come... |
New motor - 565
Model (24/28/35/36): 28 Year: 1996 Layup (pleasure/race): Pleasure (yah, baby!) Weight (empty): don't know feels "athletic" though... X-dimension: propshaft centerline is 6" below the bottom Notch (Y/N): Yup Number of engines (1/2/3): 1 Engine make/model: Miami Boys "Casper" Displacement: 565 Power: 754 (@5770) Torque: 698 (@3665) Drive: Imco Extreme SC Setback (Y/N/length): N Nosecone (Y/N/which one): N Gear ratio: 1.50 Prop (model, size, labbed, etc): T1 - Bravo 30 labbed to 31/32 LH Max speed: T1 - 71 RPM: T1 - 5000 Test conditions (wind, chop, etc): wind chop 1' Load (fuel, crew, etc): full tank (100ish gallons) 3 people 700# |
Year: 1981 Layup (pleasure/race): Pleasure Weight (empty): 5500 adv. X-dimension: 18" Notch (Y/N): N Number of engines (1/2/3): 1 Engine make/model:IRONMAN 500 Displacement: 515 Power: estimated 445 at prop Torque: medium Drive: Super Speed Power W HD 72c Borg Warner Trans Setback (Y/N/length): N Nosecone (Y/N/which one): N Gear ratio: 1.46 Prop (model, size, labbed, etc): Mercury Racing Cleaver, 15X25p stock Max speed: 63 GPS 65 livorsi RPM: 4850 Test conditions (wind, chop, etc): very light chop <.5' Load (fuel, crew, etc): 1/2 tank, Comments: I think I got the slow end covered , Gotta start somewhere, More to come... 10.2... for '08 |
Year: 1995 Layup (pleasure/race): Pleasure Weight (empty): 5500 ?? X-dimension: 17 or 17.5 I think Notch (Y/N): N Number of engines (1/2/3): 1 Engine make/model:custom Displacement: 580 Power: 750 @6k Torque: 710 Drive: xz Setback (Y/N/length): N Nosecone (Y/N/which one): N Gear ratio: 1.5 Prop (model, size, labbed, etc): bravo26 stock Max speed: 80 GPS so far RPM: 5700 Test conditions (wind, chop, etc): smooth to ripples Load (fuel, crew, etc): 1/2 tank, 2 dudes Comments: I though it would be faster:Whatever: Maybe I should sell my engine and drive and start over:D (any takers) |
| All times are GMT -5. The time now is 04:27 PM. |
