-   Pantera (https://www.offshoreonly.com/forums/pantera-39/)
-   -   Looking to Repower over the Winter (https://www.offshoreonly.com/forums/pantera/200007-looking-repower-over-winter.html)
Dono77056 12-10-2008 10:33 AM
I just had my 24SE winterized and asked the shop to look into the tapping sound my engine has been making. The mechanic put a stethaschope on the engine and said the sound is coming from the block is more likely a knock from a rod or wrist pin, on number 4 or 6. This the same side that had lower compression on the survey on the same two cylinders, thought it was in the heads. Without a complete teardown anyway to be for certain?
Worst case scenario, what's best way to go considering the economy, rebuild, upgrade or if anyone in the area has something that might work. My current setup is a 454 mag, carbed. Trying to keep this on a budget. I was told 5 - 6K to rebuild from one shop. Jasper engines, would pick up and return with a rebuild for 4K. Victory marine has 502's for about 5K.
Pantera24 12-10-2008 12:17 PM
Unless, you personally know the person rebuilding it and they guarrantee it, I wouldn't send it to get a rebuild...instead just get a new shortblock from Chevy.
https://store.gmperformanceparts.com/store/SelectProd.do?prodId=7653&redir=true&manufacturer= GM&category=Engines&name=454%20Partial%20Engine%20 &model=<!--12498778-->
Stormrider 12-10-2008 12:54 PM
how about a decent 500efi for 7500?
Dono77056 12-10-2008 02:40 PM
I'm on a budget...the 500 efi sounds nice but out of my price range....I got a quote for refreshing with the same set up for about $3500.00 I'm roughly around 400 maybe 415hp, a dyno will tell, for 6K i was quoted a bump up to 500hp with additional accessories to support the increase.
Anyone used or familiar with Owens Racing Engines in Pearland, Houston Metro area.
Dr. Dan 12-10-2008 04:31 PM
Nice low hour 502
:drink:Good friend of mine just went to larger power and is selling this low hour 502, its complete with Headers and all accessories...I know its higher than your range ...but its a clean and sharp looking package.
Can't hurt to call? Good Luck!
http://www.offshoreonlyclassifieds.c...o26410-en.html
Doc :ernaehrung004:
Dude! Sweet! 12-11-2008 09:58 AM
Aren't marine bottom ends set up with different clearances than automotive applications? So if you go to jasper or gmpp, I'd think you'd need to make sure you're getting a marine shortblock.
Dono77056 12-11-2008 10:03 PM
The jasper build would be using my long block, 4K to pick up and return door to door, stock spec rebuild.
Locally, Owens Racing Engines here in Houston has been mentioned several times. Feel free to jump in if anyone has feedback. Build costs $2500 - $2900 stock rebuild 454 mag, $3800 - $4500 to build a stroker 480hp to 525hp.
Pat McPherson 12-12-2008 01:37 PM
I'd do the stock rebuild with a little hotter cam like the 420HP Merc/Crane of the late 80s early 90s.
Add some good exhaust manifolds like Stainlees Marine and you're good to go for under $4500.
Stormrider 12-12-2008 02:16 PM
Pat, you still got leads on those volvo 496s?
IRONMAN 12-12-2008 08:27 PM
How many hours on the 454? Are you sure the exhaust gaskets are good? I don't think slightly lower compression is related to the noise but I could be wrong. I have seen where 1/4 turn on a valve adjustment and new exhaust gaskets make a 500 hr motor sound and run like new..
