-   Pantera (https://www.offshoreonly.com/forums/pantera-39/)
-   -   525 EFI+ 700 sci charger (https://www.offshoreonly.com/forums/pantera/261737-525-efi-700-sci-charger.html)
tomcei 09-07-2011 08:00 PM
No box. I'm 17-17.5 x dimension I believe.(standard on the pleasure) My prop shaft was 4-4.5" below bottom.
I will be setting up the new drive exactly like the other except 1-2" shorter. the mtr and drive and new hatch is heaver by at least 125#
I will most likely run a 5 blade 30 pitch. I can always space down to the original location somewhere in the 1-2" range. These boats need good clean water to help lift the bow and reduce slip. Not to mention if you want to run in rougher water and stay hooked up.
Do a search on "prop Shaft" B- stubs had his dialed in no doubt.
It would be interesting to see what the prop shaft is on the stepped Pantera
littledcsrodshop 09-08-2011 12:57 PM
Originally Posted by tomcei (Post 3497011)
If I had my drive I might. My ride has been parked for far too long. I have a few things finally coming together for me so it should be going by spring.
Don't want to jack a thread up, but I gotta say I'm glad to hear that brotha !! :cool:
tomcei 09-09-2011 06:45 AM
Yes, the thread has been hacked to pieces sorry Berk
Trust me, you couldn't be half as excited as I am. I'm keeping my fingers crossed. (It aint over till its over)
littledcsrodshop 09-09-2011 08:30 AM
Wish you the best dude, let me know how it works out..
Hacked & jacked thread, why ofcourse..
littledcsrodshop 09-09-2011 08:42 AM
Originally Posted by Berk (Post 3496515)
any ideas if it's a good idea or a stupid way to destroy 2 marvelous mechanics?
To late that happened within moments of buying an offshore boat regardless of your question !!
Haha !! Just messing with you guys.. I'm not personally familiar with the fuel systems on a 700 vs a 525 so my only suggestion is to make sure you have a good fuel system and I'm sure you will likewise need some efi upgrades of some sort as well.. I'm no efi dude so maybe just a tune, don't know, but make sure that part is right..
