Prop question for 28 (hard to plane)
I have a 28 twin big block pantera with bravo 1's outback spinning 4 blade bravo 30P props . I was told by the orginal owner that the x dimension was raised compared to the normal 28 pantera (has raised engine hatch and carbs/air cleaners are stuffed pretty tight against the hatch). My problem is that it is a real pain to plane. It is a touchy procedure to get it on plane without blowing the props loose in calm water. I got caught in some rough water this past week and it was impossible to get the boat to plane without blowing the props loose, I mean impossible. You almost have to see it to believe it. I was thinking of buying a set of 28 bravos as im not worring about loosing top end but am unsure exactly how much these would help. I am thinking that the 28's may break loose easier trying to plane compared to the 30's. What do you guys think?
They also make spacers to get your drives a little deeper.
Yea, i'm not sure how changing the pitch will help planing.
The spacers will help for sure. |
Check to make sure the diameter hasn't been cut down on your Bravo's. You'll want all of the diameter you can fit. You also may want to consider going up to 5 blade props. Drive spacers are also an option. Keeping the tabs down low on takeoff can help too. (around 6 or so on the indicators)
All good advice. Thanks
I get moving with the tabs level then when I get some speed and the props have a good bite I slowly bump the throttles then tab 3/4 down to get the bow to nose over. If I use positive tab before I start to plane it will start to blow the props loose. It's a real procedure unlike my last boat which I don't mind, but after not being able to get on plane on rough water I knew I have to make some changes. |
I have no problem getting on plane But I have TRS drives with a 2'' spacer also my props turn in.I think if you get those drives deeper you wont have any problems getting on plane.
my twin ran the props outward. bravo 26's. never used tabs to get on plane!!! tabs down would lift the back too soon and would get prop blowout. my flat hatch had cutouts to fit the efi intakes. a 1" spacer in the drives would be a good starting point. when i had my single 1 inch made a world of difference in the boat.
Looks like I will do drive spacers in the fall. Im may step down to some 28's if I find a good deal on a used pair to make the boat a little more friendly for cruising.
What rpm are you pulling with the 30? If you can't pull it on the top end I'd got with a smaller pitch prop. If you can pull the 30's then I'd go spacers.
Originally Posted by fantastixvoyage
(Post 3957880)
I have a 1997 Pantera with twins also turning 30 pitch Bravo 1. I have high x dimension also. I have no problem getting on plane in any conditions. I usually just throttle to 3500 RPM with drives in all the way, tabs netural. In a few seconds I am on plane. Had 28 pitch Bravos before the 30 and just saw an increase in top end. Not really any change in take off. I did add weight to the nose though for better balance about 200 lbs. of lead glassed in.
Originally Posted by jimjomack
(Post 3958076)
Originally Posted by Prostreet144
(Post 3957787)
Jimjom where and how did you glass the weight in? How did it change your ride?
Used lead shot at very front where bow hits water line. Used resin mixed with the lead then a few layers of glass on top. I then foam filled entire hull front to back. There are no open cavities. This helped a lot in ocean as it keeps the nose driving into waves. Keeps waves from pushing nose up. Also helps keeping boat level when jumping wave to wave.
Also My drives turn outward.
(Post 3957045)
| All times are GMT -5. The time now is 07:11 PM. |
