-   Pantera (https://www.offshoreonly.com/forums/pantera-39/)
-   -   280 vs. 380 (https://www.offshoreonly.com/forums/pantera/321461-280-vs-380-a.html)
The Get Away 12-27-2014 11:40 AM
280 vs. 380
Has anyone switched from the 280 kplanes to a set of 380's on a twin 28? How did the boat react to it?
kevlar382 12-27-2014 03:06 PM
I switched them on my 382 Formula. They made a big difference, I really like them. Back in the day they ran bigger tabs than that on the old 27-30 ft race boats so I think you would like them. I have extension boxes so I didn't have to trim much off them. Just a little of the corner. With out the boxes I would have had to trim a lot more off and wouldn't have ended up with much more tab than the 280. Make sure you buy the right ones, there is a difference in the bolt size of the Kiekhaefer's and the Merc Racing tabs that connects them to the transom plate.
delsol 12-27-2014 08:08 PM
I swapped them out on my 28 apache. I found it helped quite a bit as the 28 is prone to porpoise at 45- 55 mph, not nearly as aggressive tab was required in order to steady the porpoise which resulted in a faster speed...
The Get Away 12-28-2014 08:27 AM
Thanks for the reply. I have buddy buddy with a set sitting in his garage. I figured it couldnt hurt to give them a try. My pantera will porpoise around that same speed if i dont use alot of tab. Just want to get some feed back from someone that has tried them.
paul buckner 12-28-2014 09:25 AM
My twin P 28 has the big tabs and you will have to take a small amount off the inside corners or your props will do it for you Ask me how I know !!
The Get Away 12-28-2014 10:50 AM
Thanks for the heads up. Was this on a twin?
bigboat28 12-30-2014 01:44 PM
What drives and motors do you have and what is your top speed?
The Get Away 12-30-2014 07:14 PM
Trs drives, 502ci, runs 82mph.
bigboat28 12-31-2014 10:22 AM
Do you know how much hp you have?
Jake1250 12-31-2014 02:21 PM
Has anyone put the 380's on a 24?
The Get Away 12-31-2014 02:55 PM
Supposed to be 650+.
CIG3 01-02-2015 01:14 PM
Be very careful with 380's on a 24'. One wrong move and you'll be swimming.
Jake1250 01-02-2015 10:10 PM
Yeah that happened to a guy on a big power Cig 20 back in the 90's
