How tall is a 28' on a trailer?
Looking at a 28' maybe. Trying to figure out if itll fit in my shop. I have an 8' by 10' door on the shop and 40' deep. Thanks!
28' Pantera or Skater yes, 28 Cruiser Not!
There are dozens of variables; not an exact science.
Tire size Wheel size Torsion or leaf suspension Weld together trailer or bolt together trailer Steel trailer or aluminum Lifted truck, tires, wheels Flat land or hill Pavement or gravel driveway (you can scoop gravel out of the driveway so the rear truck tires dip low just as the windscreen clears a door). And different boats sit on different trailers at different angles. I've seen the exact same exact boat/hull on dozens of trailer, and seen as much as 12" of height difference at highest point. |
You should be ok with a 8' door height. My 28 is 6'-10" tall sitting on a aluminum double I-beam trailer with 15" wheels. My door 8'x12' and clears it fine.
Thanks for the input guys. I realize there can be a lot of variables so no answer will be perfect, I guess I am just looking for a general idea if it will most likely work or hell no not even close. I feel fairly confident the 8' door will work and if not I guess ill just have to make it bigger :coolcowboy:
My garage sounds like yours. the compass is a very close to the overhead door seal and actually will touch it with my new 2500HD truck. My older truck was slightly lower and had .5" clearance.
http://i741.photobucket.com/albums/x...psdgiubsbo.jpg |
Originally Posted by dawes11
(Post 4394542)
Mine is currently 6'8", but the tongue is cranked down low.
28 on a continental trailer with 15 wheels goes under my 7 ft tall door opening. With a couple inches to spare .
My old 28 easily fit under a 8' tall door............until I put the pole in for the cockpit cover:picard1:
| All times are GMT -5. The time now is 02:02 AM. |
