-   Pantera (https://www.offshoreonly.com/forums/pantera-39/)
-   -   24' Pantera Shift Cable Length? (https://www.offshoreonly.com/forums/pantera/347472-24-pantera-shift-cable-length.html)
Hammerdome 06-07-2017 11:11 AM
I need a new shift cable but it still works so I want to order one and when it comes in swap it. Dont really want to pull it just to measure it. Does anyone hapen to know the correct lenght?
vintage chromoly 06-07-2017 11:23 AM
Depends on where the shift bracket is mounted
vintage chromoly 06-07-2017 11:24 AM
Look at the exsisting cable.
should be marked with a length
Hammerdome 06-07-2017 11:54 AM
I did not know that!! Thank you!! I will look tonight.
It is mounted on the port side by the way.
64coupe 06-08-2017 01:04 PM
He means if they are top mount or side mount controls there is a two to three foot difference. The cable should be marked though and that will be the easiest way to match it.
